Does anyone happen to know what the three screws look like that are at the back of a 240Z console? Are they slotted or phillps? The PO of my car had only two screws there and they are different lengths so I don't think they are original. Was there a felt, soft or other washer under the screws? A ta p and die set seems to indicate they are 5MM at .8 pitch and the ones I have are slotted. Any info appreciated.
Edited by Mikes Z car
https://www.classiczcars.com/topic/48422-3-console-screws-towards-back/
Does anyone happen to know what the three screws look like that are at the back of a 240Z console? Are they slotted or phillps? The PO of my car had only two screws there and they are different lengths so I don't think they are original. Was there a felt, soft or other washer under the screws? A tap and die set seems to indicate they are 5MM at .8 pitch and the ones I have are slotted. Any info appreciated.
[ATTACH=CONFIG]69450[/ATTACH]
My '73 has black phillips screws. No felt.
Sean240Z, Blue, an_unusual_eye, Diseazd,
Thanks for the information, I am off to the hardware store to see what they have. I will get this console back in after having it and other parts of the interior pulled out for 3 years.
Diseazd, looking at your avatar I think that is a real troll. We have a couple in our yard but they are fakes.
No problemo. Thrify hardware here has black countersunk screws that will work though the heads are socket type. The also have zinc plated countersunk screws. To go easy on the fiberglass I think I will use a thin rubber washer under zinc plated countersunkscrews.
  • 8 months later...
Hello,
I know your post is old and you have probably moved on from this project and I'm sorry for resurrecting but....
I just put these three screws in this past weekend. I don't have a picture or screw size as I am at work but I will post a picture when I get home.
The screws were stainless steel and philips with a slightly domed head. They look pretty good. No washer used as the head of the screw sank in just enough to be flush and snug the console down.
Do you have a picture of what you used...10 months after you posted this...I'd like to see.
  • Who's Online   3 Members, 0 Anonymous, 1,354 Guests (See full list)
