Replaced ignition key cylinder.. trying to figure out how the rotation switch works
Ok, so I decided to replace the key cylinder.. Wanting a new set of keys i could than get my locks rekeyed for.
I went with an locksmart key cylinder that I got from autozone.
I had to do some altering to the part (mainly trimming the pivot point to reach the full rotation that the original had).
I got everything back together the best of my knowledge. I havent slapped it in the car yet.
My question is the switch here.. Right now it seems to be a closed circuit.. does that look about right? Is it suppose to move open?
ok i already know whats up. The replacement housing is different than the original. may need more trimming. Will finish it up tomorrow
Will this mean you have one key fits all? Something I only dream of. Mine has 4 keys :(
I have seen people remove the tumblers and reposition the pins in Opels. Is that also possible with the Zed? At least the doors and hatch would then be the same.
Goodluck with it
Chas
go to a locksmith they can actually rebuild these. Problem is you need to go to an old locksmith because the kits aren't available anymore
