Hi all;
Can anyone help me identify these parts for my 260z? Just found a bin of parts and am going through it.
Looks like maybe pic #1 is a half shaft? Pics 2 & 3 are the same parts from different angles. Ditto for pics 4 & 5.
Thanks for your help! See below.
Edited by sopwith21
https://www.classiczcars.com/topic/48670-help-me-id-these-parts/
Those are wheel axles, and companion flanges, and an odd part. Looks like the companion flanges might be adapters for turbo ZX four-bolt CV half-shafts. I saw your other post and you might want to re-word it. The half-shaft is the drive shaft between the wheel and the differential. One on each side. Typically has u-joints on each end, up until the later ZX's when they went to CV joints.
