Diseazd, Sorry to say your vacuum idea did not work for me. I will tell you why. I have removed the booster and I find that there is not a disk in there. Only thing I can think is that the PO for some reason some how lost it. If anyone looking at this thread has a used disk I would buy it. I know that Blue says to cut one and I will if I can't find a used one.
Sorry to hear that jcb. What I would do if I were you is to buy an old worthless booster on EBay.......pull out the plunger and scavenge the disc. Old boosters can be had for very little cash. You can get them from a 240 or 280. A junk yard or salvage site might also be a good place to look.
Edited by Diseazd
I was convinced mine was lost too as no kind of shaking produced a rattle inside. Luckily enough, I was able to reach in with a finger, dislodge it from the inside of the housing, and finally shake it out.
In other words, the disk was stuck to the inside of the booster housing and shaking didn't get it loose until I manually loosened.
Leon, I thought it had to be in there also but so far nothing. I tried reaching in with my finger but could not feel anything. I tried a bent coat hanger but got nothing. I am going to try to cut one. How thick and how hard do you think the rubber for the disk should be?? Any estimate is better than what I know about the thing as I have never seen one. Thanks for the reply and any info you have about the disk. JB
Here you go: http://www.classiczcars.com/forums/wheels-tires-brakes-s30/17972-reaction-disk-lost-booster.html ;)
As a precaution, I glued the disk onto the piston in the booster once I'd fished it out.
As far as hardness, I'm sure you can substitute polyurethane or polyethylene and be fine. You can find some round plastic stock (and probably rubber for that matter) on mcmaster.com and cut it out if you can't find the disk in your booster.
Edited by LeonV
  • Who's Online   2 Members, 0 Anonymous, 1,493 Guests (See full list)
