Site Updates this Weekend ×
i was driving my 70Z, and it started to sputter a bit at higher rpms, the tach was jumping around as it did. then i notice that the ammeter is pegged out at 45+ amps at anything above idle! the regulator was installed new in september 2012 ( from motorsport Z ), should this thing be bad already?? its reading 14V at the alternator, jumping to 17+ when i rev it. Any help would be appreciated.
Thanks,
Ken
https://www.classiczcars.com/topic/48891-disposable-voltage-regulators/
as indicated the alternator is putting out enough voltage, the sytem is overcharging, so I assume its the voltage regulator - replacing it this weekend.
As indicated the alternator is putting out TOO MUCH VOLTAGE when the engine is at speed. That could be caused by a bad voltage regulator, a bad alternator, or it could be caused by someone matching an internally regulated alternator with a voltage regulator.
There are a few threads from the past about the solid state MSA regulators. They were kind of sensitive, apparently, and failed quickly. Hate to say bad things about a sponsor's product, but not all of their products can be perfect. Your signs point to a bad regulator.
the alternator has been on the car for 2 years with a regulator, i'm pretty sure its OEM without an internal regulator. again, I don't think a bad alternator will overcharge, past the regulator if its functioning correctly. Has anybody else had issues with the regulators from Motorsport Z?
Thanks,
Ken
Note sure if this is pertinent, I have a 76 280z, I went through 3 alternators and 2 voltage regulators in about 2 weeks and never got the aftermarket alternator and the aftermarket voltage regulator to work properly. I had to upgrade to the new internally regulated alternator. No problems with over charging since.
  • Who's Online   1 Member, 0 Anonymous, 820 Guests (See full list)
