SilverStreak28 Posted April 2, 2014 Share #1 Posted April 2, 2014 I have cleaned the corrosion off of the wires leading into my fusible links on several occasions and they still turn green with corrosion no matter what I do to them. Would upgrading to maxi fuses help this problem or do I need to replace part of if not all of the wiring harness? Car wants to turn over but will not start, replaced the fuel pump and checked the fuel pump relay. Always had a problem with my fusible links, but I let my car sit for over a year so now I can't exactly figure out whats wrong with it and I have nothing else to drive. Please help.... Link to comment https://www.classiczcars.com/topic/48925-fusible-links-car-wont-start/ Share on other sites More sharing options...
SteveJ Posted April 2, 2014 Share #2 Posted April 2, 2014 Where in Georgia are you? Link to comment https://www.classiczcars.com/topic/48925-fusible-links-car-wont-start/#findComment-444808 Share on other sites More sharing options...
2sixTZombii Posted April 2, 2014 Share #3 Posted April 2, 2014 Can you hear the pump running? Is this an FI car? Do you have an eletrical tester, if not you can get them for really cheap at harbor freight. With that you can check for continuity between either side of the fusible links. If you know its getting fuel, then check your spark. Link to comment https://www.classiczcars.com/topic/48925-fusible-links-car-wont-start/#findComment-444810 Share on other sites More sharing options...
SilverStreak28 Posted April 3, 2014 Author Share #4 Posted April 3, 2014 Habersham County about thirty minutes from you. I work in Gainesville. Small world. Link to comment https://www.classiczcars.com/topic/48925-fusible-links-car-wont-start/#findComment-444907 Share on other sites More sharing options...
SilverStreak28 Posted April 3, 2014 Author Share #5 Posted April 3, 2014 When you turn the ignition on the fuel pump does not run and the car does not start. Wiring seems to be good from the fuel pump relay to the fuel pump. It looks like the ignition relay is not functioning. I'm trying to locate it now. Link to comment https://www.classiczcars.com/topic/48925-fusible-links-car-wont-start/#findComment-444911 Share on other sites More sharing options...
siteunseen Posted April 3, 2014 Share #6 Posted April 3, 2014 (edited) Make sure that connectors on the starter, small wire.I've run speaker wire from my battery straight to the fuel pump to test it, it's got a positive and a negative post. Edited April 3, 2014 by siteunseen Link to comment https://www.classiczcars.com/topic/48925-fusible-links-car-wont-start/#findComment-444915 Share on other sites More sharing options...
SilverStreak28 Posted April 3, 2014 Author Share #7 Posted April 3, 2014 When I ran speaker wire straight to the fuel pump it worked properly. Link to comment https://www.classiczcars.com/topic/48925-fusible-links-car-wont-start/#findComment-444916 Share on other sites More sharing options...
siteunseen Posted April 3, 2014 Share #8 Posted April 3, 2014 is the fuel line coming out of the metal fuel filter before the fuel rail hard when you pinch it, like is has pressure built up? Could be a clogged fuel filter. Link to comment https://www.classiczcars.com/topic/48925-fusible-links-car-wont-start/#findComment-444918 Share on other sites More sharing options...
SilverStreak28 Posted April 3, 2014 Author Share #9 Posted April 3, 2014 I replaced the filter when I replaced the pump. Link to comment https://www.classiczcars.com/topic/48925-fusible-links-car-wont-start/#findComment-444920 Share on other sites More sharing options...
siteunseen Posted April 3, 2014 Share #10 Posted April 3, 2014 here's my last idea, the EFI power connection off the battery. http://atlanticz.ca/zclub/techtips/electricalconnections/index.html Link to comment https://www.classiczcars.com/topic/48925-fusible-links-car-wont-start/#findComment-444922 Share on other sites More sharing options...
SteveJ Posted April 3, 2014 Share #11 Posted April 3, 2014 How anxious are you about getting this fixed? I'm tied up for the next couple of weeks, but I might be able to help you after that. Link to comment https://www.classiczcars.com/topic/48925-fusible-links-car-wont-start/#findComment-444925 Share on other sites More sharing options...
siteunseen Posted April 3, 2014 Share #12 Posted April 3, 2014 He's driving Reeboks right now! Link to comment https://www.classiczcars.com/topic/48925-fusible-links-car-wont-start/#findComment-444926 Share on other sites More sharing options...
