Gas Strut Specs.pdfI wanted to pass on some information about heavy duty struts for any ZXR owners looking to replace your weak or worn out hatch struts. I have tried a few different standard struts with less than desirable results due to the weight of the hatch with the whale tail most struts are just not the right capacity rating. I have found that the capacity needs to be a minimum of 70lbs. The original struts (Nissan #99996-R8004) I believe have an 80lb. rating. I have attached a PDF with the specs. I found that work well.
Enjoy the ride!
Phil
https://www.classiczcars.com/topic/48931-280zx-r-hatch-strut-replacement/
  • 1 year later...
