Only thing that has changed is that I got rid of my dizzy and coil since going with Megasquirt. Voltmeter on the sensor wires gives an erratic volt reading. I tried looking at the schematic and it's not making sense. Maybe gauge when tits up, but the timing of this issue makes me think it's something I did.
Any clues?
https://www.classiczcars.com/topic/48936-engine-temp-gauge-no-worky/
First thing I'de check is the integrity of the wire crimp on the bullet connector that goes on the temp sensor. Pull back the outer clear (well, used to be clear... now yellowed) boot and have a good look and maybe replace the connector. The wire strands get corrosion buildup inside and maybe only a couple of strands are barely hanging on. Same for the starter trigger connector.
  • Who's Online   1 Member, 0 Anonymous, 1,490 Guests (See full list)
