As I said before, if the running lights work, the meters should have 12 VDC+. Of course, if the harness has been hacked, all bets are off. You could check the G/W wire to ground at each meter to verify.
You should do continuity checks on the R/L wire from the rheostat back to the meters. If you have a good ground and the R/L wire is intact to all of the meters, jumpering the R/L wire to ground should give you dash lights.
  • 4 weeks later...
Sorry for the delay but just now getting back to the car and the dash. Since the weather has changed and driving season is here I have decided to put the dash back on without the lights being fixed. I will get back to it later. I do have at least one problem I need help with. I am not sure how the heater ductwork goes back together. I have included a picture of the duct part in question. Any help would be appreciated.
  • Who's Online   0 Members, 0 Anonymous, 1,385 Guests (See full list)
