Not sure what to think about this stuff. I put it in the radiator yesterday and ran the engine for 20 minutes like it says. After the engine cooled down I popped the rad cap and looked inside. I expected to see and even mix between the coolant and the additive but what I saw was like "globs" of the additive floating by. The first thing I thought was Is it possible that some of these "globs" are going to plug a passage or am I just being paranoid? Anyone else experience this? Just something else for me to worry about with this car.
https://www.classiczcars.com/topic/49107-bars-stop-leak/
I've used these products in the past. It seems like its hit or miss, and I probably would not use it again. I have had it congeal in the radiator in my Wrangler & it became an even bigger mess when I went to replace the head gasket. If the car is something you're going to keep for a long time, it'll be worth planning for replacing the head gasket/radiator and flushing the entire system. The longer this goop sits in the engine, the more likely it'll get stuck in the cracks & crevasses.
https://www.classiczcars.com/topic/49107-bars-stop-leak/#findComment-446523
A couple weeks ago the aluminum radiator in my race car developed a leak so small that it was just a bit of steam. There was no "leak" and nothing dripped. My friend had good luck in his Z with Bar's Leak and suggested that I try it. I followed the driections and it worked at first. I started it up again to set timing and adjust the carbs. 5 minutes later it was dripping out somewhere in the center of core and going onto the floor. I can't say if it's good or bad. It worked for Jeff but not for me. It's been around a long time so I'd take that as a good sign.
Chuck
https://www.classiczcars.com/topic/49107-bars-stop-leak/#findComment-446529
The Bar's material stays in gooey blob form. It just travels around, occasionally getting sucked in to a leak area, hopefully sealing it. Leak solutions are messy looking, just like the leaks. Most of them also contain lubricants for the water pump seals also. Not meant to be observed, just sealed in and left to work.
https://www.classiczcars.com/topic/49107-bars-stop-leak/#findComment-446536
Thanks Zed. I will check after a couple of days to see if the leak has stopped. Gooey blob form describes it perfectly. Guess I was more curious of what I would find when removing the rad cap.
Now I also have to replace the pan gasket, and front crank seal. Guess when it rains it pours. What I get for not driving it more often I assume. Maybe 1-2 times a week.
Chuck, I'm just going to hope for the best. I need it to hold til later this year when I can then remove the head and replace the gasket.
https://www.classiczcars.com/topic/49107-bars-stop-leak/#findComment-446553
I used some Bar's Leaks I my car a couple years ago when there was a small leak down low (from a rock?) It sealed up and I did some long trips since then and even a few runs down the drag strip. I noticed that it first discolored the coolant from yellow to tan/brown, and instead of a fine powder, it was little tiny blobs, but it has since cleared up.
I haven't had any cooling problems, AFAICT, and the engine goes just as it did before the leak. the only difference is that there is now a lower grille to keep the rocks and stuff out of the lower radiator area. I even found a paper napkin there once!
https://www.classiczcars.com/topic/49107-bars-stop-leak/#findComment-446620
I used Bar's Stop-Leak all the time when I had and raced British Cars. Came in handy on road trips! It's a real good temporary fix and should work real well in an 'L' engine. If it doesn't, the leak needs to be repaired properly. Always flush the cooling system when you make repairs.
https://www.classiczcars.com/topic/49107-bars-stop-leak/#findComment-446675
  • 3 weeks later...
As a master auto technician. If you have a leak and need to get home to repair it I use Alumaseal powdered stop leak. In 40 + year old cooling systems you can create more problems then fix with bars leak. I had a 70 Chevy that was so bad I had to get the block hot tanked and cleaned , then replace the water pump, radiator heater core and alll the hoses. My 78 was so bad the radiator weighed 27 pounds
https://www.classiczcars.com/topic/49107-bars-stop-leak/#findComment-447680
I used the alumaseal liquid and Im not convinced the leak has stopped. In about a week from now Im hopping the leak will be sealed. The car sits most of the time but will see the road everyday for the next couple of months. Thanks W. Appreciate the info. My cooling system in great shape otherwise. Just a small seepage from around the head gasket.
https://www.classiczcars.com/topic/49107-bars-stop-leak/#findComment-447685
So everything seems to be good with the leak I used to have. Hope I don't jinx myself. I used the alumaseal and it seems to be working. I can actually see where the aluminum powder seeped out where the leak was and now looks and feels dry. I didn't think it would work. Glad it did. Will probably be pulling engine towards end of year so hope it lasts til then. It is a daily driver now.
https://www.classiczcars.com/topic/49107-bars-stop-leak/#findComment-448450
