Looks like I have a coolant leak between the head and the block, right near the back of the engine, close to the transmission.
I'm assuming this is clearly a head gasket? Not having much luck with this car so far. The oil is still clear (Not milky).
Edit: Sorry. the photo is upside down, I can't figure out why. It's upright on my computer.
https://www.classiczcars.com/topic/49111-coolant-leak/
Thanks for the picture rotation!
Good to know it's possible it could only be a coolant leak. I guess the only real way to check is to do a compression test?
Is there any other heads I could swap on here that won't drastically reduce my compression ratio, yet increase performance a little over my E88? I can't seem to find an engine calculator that works for the L24 block.
If a HG replacement is required, it would be nice to be able to swap on a useable/straight head right away and have the car on the road again the same day.
https://www.classiczcars.com/topic/49111-coolant-leak/#findComment-446570
