Hey Matt, how did you set your camber on the BC coilovers? Before installation? Can you make adjustments without removing them as I see you didn't cut your strut towers....
I initially installed them at the "0" mark. I ended up adjusting the rears 2 degrees in. You have to raise the car, unbolt the coilover at the strut housing, then adjust it with an allen wrench. Not the easiest but once its set, its done.
