May 29, 201411 yr comment_448776 Greg,It sounds like you're back up and going. (For the record, after reading this post & BEFORE you did your last round of cleaning, I was thinking the same thing Blue said...the WOT pulse shaping circuitry in your ECU was kaput. I do think now it was just bad external connections.) If you still think it might be the ECU, give me a yell. I have several old stock units. I can send you a loaner one to compare against yours to see if it makes any difference. You can send back yours if you decide the loaner is better. I don't care if I get back a goofy-running ECU.Len Link to comment https://www.classiczcars.com/forums/topic/49252-strange-issue-with-78-280z-running-im-at-the-end-of-my-rope/?&page=5#findComment-448776 Share on other sites More sharing options...
June 5, 201411 yr comment_449232 I had an issue with my 280z and took years to resolve. It ended up being a temperature sensor. The car would run rich with no performance and would run only between 2,000 and 3,000 rpm. This would happen intermittingly until the sensor completely failed. This was a problem with a lot of the 78Z's. I hope this sheds some light to your problem. Link to comment https://www.classiczcars.com/forums/topic/49252-strange-issue-with-78-280z-running-im-at-the-end-of-my-rope/?&page=5#findComment-449232 Share on other sites More sharing options...
June 5, 201411 yr comment_449265 I am once again amazed by the enormous amount of knowledge by folks in this club! Link to comment https://www.classiczcars.com/forums/topic/49252-strange-issue-with-78-280z-running-im-at-the-end-of-my-rope/?&page=5#findComment-449265 Share on other sites More sharing options...
