Yamahacam Posted May 24, 2014 Share #1 Posted May 24, 2014 Does anyone know if the accelerator shaft support bush is still available? All of the ones I have are crumbling to pieces. Is the part number 18311 P1100? Link to comment https://www.classiczcars.com/topic/49296-acc-shaft-bush-part-number/ Share on other sites More sharing options...
Yamahacam Posted June 23, 2014 Author Share #2 Posted June 23, 2014 Spoke to Nissan and told they told me they are no longer available. Will have to make something myself. Link to comment https://www.classiczcars.com/topic/49296-acc-shaft-bush-part-number/#findComment-450292 Share on other sites More sharing options...
zKars Posted June 23, 2014 Share #3 Posted June 23, 2014 Remove the old crumbled center and spot weld in a nice little bearing with the right ID. Or just swap to a cable system. Much better. Link to comment https://www.classiczcars.com/topic/49296-acc-shaft-bush-part-number/#findComment-450308 Share on other sites More sharing options...
Yamahacam Posted June 23, 2014 Author Share #4 Posted June 23, 2014 Was thinking of trying to get a bearing in there. Thanks Jim Link to comment https://www.classiczcars.com/topic/49296-acc-shaft-bush-part-number/#findComment-450321 Share on other sites More sharing options...
240k Style Posted June 23, 2014 Share #5 Posted June 23, 2014 I have a parts book if you need Cam? Link to comment https://www.classiczcars.com/topic/49296-acc-shaft-bush-part-number/#findComment-450338 Share on other sites More sharing options...
