Can anyone confirm that the white/black wire is correctly soldered? It is attached to the side of the metal part while the other 3 are soldered through it and on to other wires that go in to the radio.
There was evidence of tampering with the cap that goes over the wires so I just wanted to confirm if this looks correct. I haven't powered it up yet.
Edited by That Ozzy Guy
Does anyone know what the black toggle switch above the tuner knob does? It's actually inside the unit and not accessible while the case is assembled. Turning the knob, pushing or pulling it while turning it etc does nothing to it.
I had a closer look tonight and figured it out. When the dial is attached you press it in and the grooved part of the larger stem is engaged by the dial which in turn actuates the switch. As to what it does, I still have no idea. Need to read the manual.
Incidentally, the volume side has a similar action but it's something other than a switch that's controlled when pressed in. Again, need to read the manual.
  • Who's Online   2 Members, 0 Anonymous, 1,493 Guests (See full list)
