SteveJ,
Was the park in the up position issue because the slot on the motor shaft was 180 out where the linkage goes over the motor shaft? Searching would be better but that is what I think I remember.
Mike
Edited by Mikes Z car
What you can try although it's time consuming is to turn off the wipers see where they are parked, take the wiper arms off the spindles and position them in the proper park position, turn them back on and see if they work correctly. It sounds like the wiper arm is 180 out. Just my 2¢.
Edited by mjr45
