ABOUT TO BUY THIS 240Z.. What u Reckon?
Um Hawkwind did u say that it's a 71mdl????
I'm almost convinced it's a 260z not a 240z.
This is why unless I've read wrong.
2.6ltr engine L26 came in 260z.
The Dash is the 260z style dash.
The bonnet is a 260z fluted bonnet.
Your proxy setting for MSN and ICQ should be the same as it is for Internet Explorer/Netscape.
Copy and paste it from there. At my Uni they tried to stop us using it by installing a program called PROGKILL. It's easy enough to remove from the system tray using cntrl alt delete to select and end task. I suspect if my Uni has used it maybe yours will do the same.
I'll go over all the posts to see if I'm wrong.
For 5500, i would expect it to be in nice condition, but not great, if you want to see what you get for 900 have a look at my gallery, its not much ROFL but i figured on my budget it was going to be a full and gradual rebuild, so why start with an ok car, when you can start with a rough car put a similar amount of $ into it and still coem out with the same result For 5500 it doesn't look like a bad bus
Hi All,
does anyone know the contact details of this Carlos guy from Sports Classics?
My brother is currently living in Mosman, Sydney and I was thinking that maybe if there was a nice 240Z...I could always do with one more Z!
Please post Carlos' phone number, address, web page, email address, fax number etc if possible.
Thanks in advance,
Cuong Nguyen
(there is always more 240Z for sale in the east coast than here in WA :( )
Originally posted by Hawkwind
But i can't figure out what the proxy adress is to get my MSN or ICQ to werk :( ! ! !
Probably nothing to do with proxy addresses. The Network admin has probably blocked all the ICQ ports with a firewall.
Try ICQ 2 go. Its a java applet that runs in a browser window and seems to work when normal icq cant.
http://go.icq.com
Originally posted by Cuong Nguyen
Hi All,
Thanks in advance,
Carlos Casmiri
Ph (02) 4776 1174 Mob 0418 284 776 Fax (02) 4776 2111
sales@sportsclassic.com.au
www.sportsclassic.com.au
1077 Castlereagh Road Castlereagh NSW 2749
PO Box 1257 Penrith NSW 2751
Originally posted by That Ozzy Guy
Carlos Casmiri
Biker...
  • Who's Online   2 Members, 0 Anonymous, 910 Guests (See full list)
