Posted July 7, 201410 yr comment_451146 Is there any 'easy' way to do this? I'm trying to remove all of my interior trim to run new speaker wires, but the damn panel retainers are so small and tight I can't get any to pop out. My interior is perfect and crack free and I want it to remain that way. I also have no broken or missing panel retainers. I also like that. Link to comment https://www.classiczcars.com/forums/topic/49590-removing-panel-retainers-240z/ Share on other sites More sharing options...
July 7, 201410 yr comment_451147 Matt, are you pushing the pins through first? Stock retainers have a pin going through them. Link to comment https://www.classiczcars.com/forums/topic/49590-removing-panel-retainers-240z/#findComment-451147 Share on other sites More sharing options...
July 7, 201410 yr comment_451154 By "pins" he means in the center of the retainers. They might not be that visible, but if you get a thin nail and push it into the center of the retainers, the pin should push through. Then you can pull the fasteners out. And you will probably be able to find most, if not all of the pins once you remove the interior panels. Link to comment https://www.classiczcars.com/forums/topic/49590-removing-panel-retainers-240z/#findComment-451154 Share on other sites More sharing options...
July 8, 201410 yr comment_451159 And Matt, if you need replacement retainers, I have a bunch. Link to comment https://www.classiczcars.com/forums/topic/49590-removing-panel-retainers-240z/#findComment-451159 Share on other sites More sharing options...
July 8, 201410 yr comment_451199 Nissan part #90909-E4100 for black. My guy charges me $.88 a piece, packs of 10, just bought 30 and they're still available from the dealer. Edited July 8, 201410 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/49590-removing-panel-retainers-240z/#findComment-451199 Share on other sites More sharing options...
July 8, 201410 yr comment_451200 Actually there is a Ford fender retainer that is available on ebay for about $13 for 50. It's VERY difficult to tell them apart. Link to comment https://www.classiczcars.com/forums/topic/49590-removing-panel-retainers-240z/#findComment-451200 Share on other sites More sharing options...
July 9, 201410 yr Author comment_451243 Thanks guys! I feel absolutely stupid for not noticing that, I popped them all out and couldn't manage to recover any of the pins, so I'm just going to order a big mess of them. Also didn't have as much speaker wire as I though, so I used some of my large gauge primary wire. Fail on my part, I need to stock up on audio wire. Link to comment https://www.classiczcars.com/forums/topic/49590-removing-panel-retainers-240z/#findComment-451243 Share on other sites More sharing options...
July 9, 201410 yr comment_451252 Matt, before you pay $9 for 10, look at this thread: http://www.classiczcars.com/forums/interior-s30/42851-fasteners-trim-panels.htmlAnd they are still available: 50 FORD FENDER SHIELD PUSH TYPE RETAINERS OEM 387843-S on eBay! Link to comment https://www.classiczcars.com/forums/topic/49590-removing-panel-retainers-240z/#findComment-451252 Share on other sites More sharing options...
July 9, 201410 yr comment_451288 An easy way to get the pins out from their dark recesses is to put a handkerchief over the nozzle of your shop vac. Leave some room and secure with a wire tie. Turn on vac, collect said pins, turn off when you can drop the pins into your hand. Been there, done that, works every time.Cheers, Mike Link to comment https://www.classiczcars.com/forums/topic/49590-removing-panel-retainers-240z/#findComment-451288 Share on other sites More sharing options...
July 19, 201410 yr comment_451859 Did the E-Bay retainers work out good? I'd like to have a bag.Whops! I read the other thread and see where Steve bought them. Thanks for the tip Steve. Edited July 19, 201410 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/49590-removing-panel-retainers-240z/#findComment-451859 Share on other sites More sharing options...
July 19, 201410 yr comment_451861 You're welcome, Cliff. Link to comment https://www.classiczcars.com/forums/topic/49590-removing-panel-retainers-240z/#findComment-451861 Share on other sites More sharing options...
July 19, 201410 yr comment_451867 An easy way to get the pins out from their dark recesses is to put a handkerchief over the nozzle of your shop vac. Leave some room and secure with a wire tie. Turn on vac' date=' collect said pins, turn off when you can drop the pins into your hand. Been there, done that, works every time.Cheers, Mike[/quote']How come I never thought of that?Great tip, thanks!Dean Link to comment https://www.classiczcars.com/forums/topic/49590-removing-panel-retainers-240z/#findComment-451867 Share on other sites More sharing options...
