Hi I'm new to this page and the car only owning it for 2 months. Being 17 and being used to dealing with carburetors. So to the issue it is running rich I have replaced the coolant temp sensor and the 7th injector plug, have adjusted the air/fuel screw also but still getting too much fuel, please help.
https://www.classiczcars.com/topic/49597-1975-280z-efi-problems-help/
If you read a few more threads on "running rich" you'll see it recommended often, to measure resistance of the coolant sensor circuit at the ECU. There are several connections along the way that can add resistance. What the ECU sees is what matters.
Download the Electronic Fuel Injection Guide from the first link below. Get a meter, even a simple one will do. Try to find a way to measure fuel pressure. Read the Engine Fuel chapter, especially the first few page, if you want to understand how all of the parts work together. You'll waste a lot of money if you just guess and replace parts.
XenonS130 - S130 Reference
Amazon.com: multimeter
XenonS30
Index of /FSM/280z
  • Who's Online   2 Members, 0 Anonymous, 521 Guests (See full list)
