My 72 240z is taking me on a shop tour .....3 trys at 3 shops and I still have a rear wheel that is kinda stuck/ slow turning...binding up......not turning fluidy. Pretty sure brake related...
Shop1....Start after I replaced driver side rear wheel cylinder....took back readjust...
Shop2....Adjust brake seemed better....but after a short time sticking again bad....
could use of ebrake make this happen? (like it doesnt completely release?)
Shop3..."yeah man that brake was locked up....we had to use a rubber malit on it and it broke the brake drum" well I got a new drum....they felt they fixed it....on the way home after a mile I heard a brake related rubbing but this time in Pass rear wheel.....I stopped called AAA again....
The rim was so hot.....only one like that...
Please help any insight....or even a great z shop in la....
Love my Z hate this one dingleberry.
thanks
Pat
https://www.classiczcars.com/topic/49627-pass-side-rear-break-sticking/
Seems to me theres probably $40 worth of parts in a rear drum assembly. I suspect your springs are worn out or the brake adjuster in the drum gave up. In either case a full brake job seems cheap enough to just take the shotgun approach to this problem.
when I was refurbing my parking brake I totally removed the cable, then used a cable lubricator for a motorcycle. First I sprayed in wd-40 to clean everything out, compressed air to removed the wd-40 then cable lubricant. one of my other hobbies is dirt biking so I had a cable lube tool lying around, but gravity and light oil will give you the same effect. This is what i used
Use the page from the FSM and do it yourself ( if possible ) or find a real garage that knows what they are doing. We do know that your brake is not releasing properly, there are many things that can cause that.
Edited by bartsscooterservice
  • Who's Online   1 Member, 0 Anonymous, 853 Guests (See full list)
