It has finally arrived :) - Page 3 - Introductions - Classic Z Car Club Skip to content
as the brakes have been alright now and filled with ATE blue fluid
got the geo setup properly today. Thanks to the ACZ components that saved quite some time during the
setup. seemed to be a good investment to lower the spring rates on the front and rear and car handles now
spot on.
  • 1 month later...
got the carbs set up the last two days and one of those 123 tune ignition distributors in the car.
currently just lot´s of rain so had to prep the car some days prior with loads of fluidfilm to prevent
any rust and to soften up the old sealing below the car. around 5L went in all the wholes and under the car.
acceleration bog is now gone and car is crisp on thew throttle. wasnt quite cheap but good addy
to go to. friendly service and youre allowed to stay in the workshop while the work is done and anything
in regards of carbs get´s explained in detail. my carbs had been from 2003 and needed a full refurb.
as engine wise anything is almost done i can leave that aside and continue with the interior.
in the meanwhile new flywheel and two gearbox rebuilt kit´s have arrived.
had some time those days and the weather is soso so started working on the car again.
removed the stuff that had been on the floorboards to take a closer look if there is any rust
before the new interior comes in.
nothing major but rust oil and dirt needs to be cleaned up.
as the dash needs to come out anyway pulled that too. one of those heater bolts drove me crazy but after some time
got that done too. frontscreen will be taken out the next days as a new one comes in and fresh headlinerIMG_20141226_155111.jpg needs to be fitted too.
Those floor pans look great.  That car has been kept inside, apparently.  Is that paint #110 Persimmon Red?  I've got that color with white interior.  Didn't like it at first but now it's growing on me, the white interior.  I had to put a cover over the driver's seat and now I can wrench on it and jump in and drive without changing clothes.  :)
youre right :) paint should be #110 Red. It has been repainted outside but it is not a full 100 percent match with the interior red.
not obvious if you don´t take a real close look.
did prep the floorboards with rustbuster. they seemed to be clean but once you apply the stuff it shows different.
similar thing here with the interior. in the first place i did not want to switch color. we tried to match color
headliner seats and plastic parts. almost no chance. tried to clean the vinyl headliner to see its original
color and it´s more kind of cream than white so problem with new plastic parts as they are deeper color as
the rest. so we skipped the white and now we get the whole picture in black. interior sparco seats rollbar
carpet plastic parts are already finished in black and ready to go. next will be front screen comes out
for new headliner and floorpans get painted red again. next will be new wiring of the wideband lambda
and the greddy gauge. rest of the gauges will be kept to keep the classic look.
some time ago found a rotten 280zx in a garage they guy was parting out. didn´t want to do any more work on the
car so drove there today and started to take the gearbox and diff out. have seldom seen so much rust in total on a car
but it seemed it stood outside for a long long time. engine and gearbox were running no prob and diff seems to be ok too.
if i remember correctly it should be a 82 NA 280ZX. not sure if there is a difference in gearbox and diff rations on the european
cars ?
some pictures of the items that got rescued
diff was a messy job. all the nuts shot but managed to get it loose.
the rear bolts of the diff came out as nuts were shot :)
currently thinking of getting the motor too. N54 block and P90A head. dont realy know what to do with it
maybe built a second stroker if my engine goes bang but what ive read nobody uses the P90A head ?
