Exactly which bearings are needed to rebuild an R200 Diff?
I see in the Black Dragon catalog for the R200 they list the side carrier bearings (2), the front pinion bearing, and the rear pinion bearing. However, they don't list a pilot bearing like they do for the R180. Doesn't the R200 have a pilot bearing?
I'd really appreciate it If someone who has done a rebuild on the R200 could verify and list for me exactly which bearings are needed.
Also, if I knew exaclty which to order it looks like I could save quite a bit of money through Rock Auto for example instead of buying a rebuild kit.
Gary
Datsun 240Z/260Z/280Z Differential Gear, Pinion & Cover (R200)
1 ASSY-FINAL DRIVE 37/
38300-N3200 MANUAL 2+2 SEATER - 7408 1
ASSY-DINAL DRIVE 37/
38300-N3205 MANUAL 2+2 SEATER 7409 - 7411 1
ASSY-FINAL DRIVE 39/
38300-N3305 7508 - 1
ASSY-DINAL DRIVE 39/
38300-N3306 7412 - 7507 1
2 COMP-HOUSING FINAL D
38310-N3100 - 1
3 BOLT-BEARING CAP (M1
38315-N3100 - 4
4 SERVICE FILE COVER-REAR
38351-N3100 - 1
5 PLUG-FILLER
38357-E4600 - 1
6 ASSY-PLUG DRAIN
32103-U8400 - 1
7 STUD-REAR COVER
38354-N3100 - 2
8 WASHER-SPECIAL,F
54474-N3100 - 2
9 NUT-SELF LOCKING
08912-84410 - 2
10 BREATHER
38352-78600 - 1
11 PACKING-REAR COVER
38353-N3100 - 1
12 BOLT-HEX WITH WASHER
08120-82562 - 8
13 SET-HYPOID GEAR 37/1
38100-N3200 MANUAL 2+2 SEATER - 1
SET-HYPOID GERA 37/1
38100-N3200 MANUAL 2+2 SEATER - 7408 1
38100-N3205 MANUAL 2+2 SEATER 7409 - 7411 1
SET-HYPOID GEAR 39/1
38100-N3305 7412 - 1
14 BOLT-DRIVE GEAR
38102-N3100 - 10
15 ASSY-DIFF CASE & GEA
38420-N3100 - 1
16 CASE-DIFF
38421-N3100 - 1
17 ASSY-SIDE GEAR
38422-N3100 - 2
18 CIRCLIP-SIDE YOKE
38225-N3100 - 2
19 MATE-PINION DIFF BEV
38425-N3100 - 2
20 WASHER-THRUST SIDE (
38424-N3100 - 2
38424-N3101 - 2
38424-N3102 - 2
21 SHAFT-PINION MALE
38427-N3101 - 1
22 PIN-LOCK MATE SHAFT
38428-U1500 - 1
23 ASSY-BEARING DIFF SI
38440-N3100 - 2
24 WASHER-ADJUST DIFF S
38453-N3100 - 2
38453-N3101 - 2
38453-N3102 - 2
38453-N3103 - 2
38453-N3104 - 2
38453-N3105 - 2
38453-N3106 - 2
38453-N3107 - 2
38453-N3108 - 2
38453-N3109 - 2
38453-N3110 - 2
38453-N3111 - 2
38453-N3112 - 2
25 SPACER-DIFF SIDE
38454-N3100 - 1
26 ASSY-FLANGE SIDE RH
38220-N3100 - 1
27 ASSY-FLANGE SIDE LH
38230-N3100 - 1
28 SEAL-OIL SIDE FLANGE
38342-N3100 - 2
29 ASSY-BEARING PINION
38120-61000 - 1
30 ASSY-BEARING PINION
38120-13201 - 1
31 SPACER-PINION PILOT
38169-N3100 - 1
32 ASSY-BEARING BALL JO
38335-N3100 - 7408 1
ASSY-BEARING BALL PI
38335-N3200 7409 - 1
33 SPACER-PINION BEARIN
38165-61001 - 1
38165-B4002 - 1
38165-B4003 - 1
38165-B4004 - 1
38166-61001 - 1
34 WASHER-ADJUST PINION
38125-61001 - 1
38126-61001 - 1
38127-61001 - 1
38128-61001 - 1
38129-61001 - 1
38130-61001 - 1
38131-61001 - 1
38132-61001 - 1
38133-61001 - 1
38134-61001 - 1
38135-61001 - 1
38136-61001 - 1
38137-61001 - 1
38138-61001 - 1
38139-61001 - 1
35 WASHER-ADJUST DRIVE
38154-B4017 - 1
38154-B4018 - 1
38154-B4019 - 1
38154-B4020 - 1
38154-E4600 - 1
38154-E4601 - 1
38154-E4602 - 1
38154-E4603 - 1
38154-E4604 - 1
38154-E4605 - 1
38154-E4606 - 1
38154-E4607 - 1
38154-E4608 - 1
38154-E4609 - 1
38154-E4610 - 1
38154-E4611 - 1
38154-E4612 - 1
38154-E4613 - 1
38154-E4614 - 1
38154-E4615 - 1
38453-28500 - 1
38454-28500 - 1
36 SEAL-OIL DRIVE PINIO
38189-N3100 - 1
37 ASSY-FLANGE COMPANIO
38210-N3100 - 1
38210-Y0800 7412 - 7507 1
38 NUT-DRIVE PINION
38216-N3100 - 1
Thank you Blue. Like the R180, it does look like there are 3 bearings associated with the pinion in the R200 but for whatever reason Black Dragon doesn't show the front ball joint bearing. And that is probably the one thats making the howling (whinning) noise.
Gary
In most cases you don't need to replace the bearings in an R180 or R200. They are pretty sturdy and if the diff has had the fluid changed a couple times in its lifetime the bearings are probably still good.
Incorrect pinion and crown wheel contact is the main cause of diff whine. If bearings are gone than the pinion and crown will need work as well. Might be better off looking for a new diff.
You can use "bearing blue" or the red stuff, can't think of its name right now, to check the contact patern and refer to fsm. Its a lot of hassle getting it right if you don't have the right special tools to measure pinion height etc. A diff specialist would have a better chance getting it adjusted.
Chas
I wasn't going to try to rebuild it myself. I found a Trany/diff specialist who say he can do it. However, I was going to order all the parts myself (eg bearings, seals, gaskets) hoping to get good quality at a reasonable price and then just pay him for all the labor.
Gary
I dont know what quality bearings BD use, but all the bearing are still available through Nissan except the pilot bearing. They would have to measure it when they remove it or if its in good condition reuse it.
The four available bearings will cost about $230 IIRC.
If you are thinking of a rebuild, this would be probably the minimum:
Side bearings: 38440-N3100 (2)
Pilot bearing: 38335-N3100 NLA
Pinion bearing: 38120-13201 (front)
Pinion bearing : 38120-61000 (back)
Front seal: 38189-N3100
Pinion shaft nut: 38216-N3100
Side seals: 38342-N3100 (2)
Diff cover gasket: 38352-N3100
Breather: 38352-78600
Chas
Hi Chas. I googled each of those part numbers and they all see to be available, even the Pilot Bearing, from a couple of different distributors at reasonal prices. For example;
Axle Differential Bearing | Genuine Nissan | 38440-N3111
Thanks for listing them for me
Gary
  • 5 years later...
  • Who's Online   2 Members, 0 Anonymous, 1,446 Guests (See full list)
