Help! Cold start valve has no place to connect to fuel rail
Another option: Put a "tee" in your fuel line between your fuel filter and fuel rail. Then connect the CSV to that "tee," running another line across the front of your engine. That will hold you until you get the correct fuel rail at some future date, or if you don't care about the cosmetics of that solution, it should work every bit as well as the original design.
Edited by FastWoman
