S30Driver Posted August 27, 2014 Share #1 Posted August 27, 2014 Completed my installation of a fuse block to replace the ageing fusible links. Used the same Mini ANL block that Mike W used in his 260, except purchased the 4 fused output block. One 80A ANL for the alternator feed back, and three 50A for the other circuits were the fuses I used. This model has 2 inputs so I will eventually run another cable from the unused port to a inexpensive 2 output small fuse block without the digital bling for the FI links. The display has 4 led's for the fuse status, and the system volts / current. The display cycles between volts & amps about every 10 seconds and shuts itself off in 90 seconds if there is no circuit activity. A good thing, I was worried it would stay lit up all the time & was getting ready to put a small toggle switch on the ground wire for the display to kill it. Worked out well. Fairly accurate, shows my battery to be 12.9 volts when the car is off. Shows my parking / dash lights are 3 to 4 amps when on. 3 Link to comment https://www.classiczcars.com/topic/49927-280z-fusible-link-upgrade/ Share on other sites More sharing options...
jimbob_racing Posted September 29, 2015 Share #2 Posted September 29, 2015 Do you have any info on the block? Manufacturer name/part number? Source to buy from? Link to comment https://www.classiczcars.com/topic/49927-280z-fusible-link-upgrade/#findComment-478187 Share on other sites More sharing options...
Mike W Posted September 29, 2015 Share #3 Posted September 29, 2015 It's made by Db Link. I originally used the 2 position version and it has worked out great. You can find them on Amazon here: http://www.amazon.com/gp/product/B000P0XYU8?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00 Hope that helps. Let me know if you have any other questions. Mike. Link to comment https://www.classiczcars.com/topic/49927-280z-fusible-link-upgrade/#findComment-478189 Share on other sites More sharing options...
wheee! Posted September 29, 2015 Share #4 Posted September 29, 2015 Definitely going this route.... Link to comment https://www.classiczcars.com/topic/49927-280z-fusible-link-upgrade/#findComment-478191 Share on other sites More sharing options...
TomoHawk Posted September 30, 2015 Share #5 Posted September 30, 2015 (edited) IMO, replacing the fusible links with fuses is a very dangerous thing. Who started all the fusible link- fuse equivalence stuff?? The fusible links are protecting some very important things that draw a lot of current, like the headlamps and the fuel injection system, and you will have instantaneous trouble if the fuses melted. Fusible links are like circuit breakers, so you would want to use those in stead. You can get circuit breakers that plug into fuse clips. Edited September 30, 2015 by TomoHawk Link to comment https://www.classiczcars.com/topic/49927-280z-fusible-link-upgrade/#findComment-478217 Share on other sites More sharing options...
wheee! Posted September 30, 2015 Share #6 Posted September 30, 2015 As I understand it, the function is pretty much the same in a fusible link as it is in a Maxi Fuse. Current draw above the rated size of the link or the fuse causes the wire or fuse to melt and opens the circuit. Why would it act any different? This article explains it fairly well... http://www.autoshop101.com/forms/hweb1.pdf Link to comment https://www.classiczcars.com/topic/49927-280z-fusible-link-upgrade/#findComment-478223 Share on other sites More sharing options...
TomoHawk Posted September 30, 2015 Share #7 Posted September 30, 2015 (edited) Maxi Fuses are bigger than the standard fuses, but still aren't the same as fusible links. Without re-engineering the wiring for fuses, you invite unpredictable results. Edited September 30, 2015 by TomoHawk Link to comment https://www.classiczcars.com/topic/49927-280z-fusible-link-upgrade/#findComment-478264 Share on other sites More sharing options...
wheee! Posted September 30, 2015 Share #8 Posted September 30, 2015 Maxi Fuses are just more robust fuses, but still aren't the same as fusible links. Without re-engineering the wiring for fuses, you invite unpredictable results. I don't disagree in theory, however, I am of the opinion that fusible links inherently invite more risk of failure than a Maxi Fuse. Fusible links are merely wire of a gauge 4x smaller than the rated current of the device it is protecting. In case of an overcurrent, the wire melts withing the heavy duty sheilding and protects the circuit. A Maxi Fuse does the same thing, only in a fuse style and in a design for high current draw circuits. If Maxi's had been available at the time, Datsun would probably have used them instead. At that time, fusible links were the traditional method of securing high amperage circuits for which fuses were not rated. IMHO Maxi Fuses are an elegant solution to an older technology. Maxi's provide a quick visual reference to the condition of the circuit as well. Fusible links are visually harder to identify as serviceable... Link to comment https://www.classiczcars.com/topic/49927-280z-fusible-link-upgrade/#findComment-478266 Share on other sites More sharing options...
TomoHawk Posted September 30, 2015 Share #9 Posted September 30, 2015 (edited) They still use fusible link in modern cars. My 1997 has all three kinds, regular blades, cartridges, and fusible links. I would rather use the cartridge than a Maxi fuse, They were designed to be more robust than regular fuses, like the fusible link. It's true that you'll need to diligently maintain the electrical system so fusible links can perform as they did when the car was new, but it easier than replacing the entire electrical system. Edited September 30, 2015 by TomoHawk Link to comment https://www.classiczcars.com/topic/49927-280z-fusible-link-upgrade/#findComment-478268 Share on other sites More sharing options...
wheee! Posted September 30, 2015 Share #10 Posted September 30, 2015 I have had a hard time finding a fuse block that will work with the cartridges. I agree they are more similar to the fusible links. As I am doing the whole car anyways, one of my plans was to clean up the engine bay. Pallnet fuel rail, hidden injector wires, rerouted fuel lines, carbon canister, brake booster and vacuum lines etc. Adding the Maxi Fuses as a way to eliminate the fusible link connection is a real easy step and I will move them to the firewall along with the fuel pressure regulator and fuel filter. Link to comment https://www.classiczcars.com/topic/49927-280z-fusible-link-upgrade/#findComment-478270 Share on other sites More sharing options...
Patcon Posted September 30, 2015 Share #11 Posted September 30, 2015 Captain Obvious or SteveJ have thoughts on this? Link to comment https://www.classiczcars.com/topic/49927-280z-fusible-link-upgrade/#findComment-478271 Share on other sites More sharing options...
TomoHawk Posted September 30, 2015 Share #12 Posted September 30, 2015 I'd like to see a write-up of how to route the fuel injector wires so they go along the firewall, then to the back of the intake manifold. 1 Link to comment https://www.classiczcars.com/topic/49927-280z-fusible-link-upgrade/#findComment-478278 Share on other sites More sharing options...
