From Main (Home) Page at the Club site, on the left side near the top is the "OPTIONS" Menu, select , "USER CP" that takes you to the User Control Panel page. Select "EDIT OPTIONS " from the bar across the top of the page. That takes to to the "OPTIONS " page. On that page scroll to the bottom and select the button that says "CHANGE AVATAR ". That will take you to a page where you can select from a list of avatars that Mike offers OR you can scroll to the bottom of the page to the area called CUSTOM AVATARS to either upload an avatar from another website or (as most of us do) click the BROWSE button to select a picture from your own computer to upload to the club site. Note the size limitations mentioned below the words USE CUSTOM AVATAR. After you have selected the picture that you want to use, click the SUBMIT MODIFICATIONS button, your done!
Depending on the picture that you choose you may need to re-size it to fit the 150 by 150 pixel limitation. That was the most difficult part for me. I stumbled my way through that, so I really can't offer intelligent directions on how to do that part, but I did use the MS PAINT program that came on my computer to manipulate the image size.
Hope this helps you.
Carl
https://www.classiczcars.com/topic/4998-avatar-change/#findComment-28891
