Mix Door and Air Box Sealing
Hello all,
I have done some searching on how to seal the air box and the door in the air box. What I am curious about is how long these solutions lasted.
http://www.classiczcars.com/forums/open-s30-z-discussions/25172-changing-out-heater-core-1971-240z.html#post208917
For the door (in the thread above) folks recommended self-adhesive weather stripping for doors and windows as well as gluing a mouse pad to the door.
http://www.classiczcars.com/forums/interior-s30/21508-how-seal-cowl-vent-blower-motor.html
For sealing the box folks were recommending plumber's putty, dum dum, A/C tape, and foam weather stripping.
Can anyone report on how long these fixes have lasted?
I like the mouse pad idea. I just wonder how well the neoprene will hold up to the heat.
Thanks in advance for the help!
https://www.classiczcars.com/topic/49982-mix-door-and-air-box-sealing/
Ben, as long as you use good quality materials there is no reason to believe they won't last many years. I rebuilt my heater box 2 years ago and it is working well but then I only use it in the early spring and late fall.
I used thin foam backed vinyl from an Auto Upholstery shop for the faces of the baffle doors.
Chris
  • Who's Online   0 Members, 0 Anonymous, 1,485 Guests (See full list)
