I have scanned through the various Mallory threads but didn't find exactly what I was looking for so bear with me if I am covering old ground here.
I just purchased a Mallory distributor with a mechanical advance for my 1973 240 running triple Webers. I currently have a stock dizzy, stock coil, ballast resistor, etc.
Leading to the distributor, I have three wires - yellow going to the water temp sensor, a black wire and a green wire both attached to the dizzy. The green wire seems to just attach to the outside of the unit (ground?).
Can I just run the black and green wire into the new Mallory unit with no further changes (keep all the other components the same)?
I constantly hear about people who do and do not have tach problems - have we reached a consensus on whether this is a consistent problem? Is there a fix for it?
I haven't actually received the Mallory unit yet - can I expect decent instructions from them?
Thanks for any information you can provide.
(Note: Car is a 4-speed currently with a single-point distributor)
Edited by jharvat
DO NOT hook up the Unilte without reducing the voltage feed to it - you can burn it out.
This might help..
Mallory UniLite Hook Up<br> for 72 Datsun 240Z
the wiring there is for a 72 - and I can't remember if the 73 Tach is exactly the same or not.
FWIW,
Carl B.
Here's a little extra info, in addition to Carl Beck's. In case the unit doesn't come with its own or to plan ahead.
http://prestoliteperformance.com/media/instructions/mallory/Mallory_Instructions_unilite_distributor_37_38_45_47.pdf
  • Who's Online   3 Members, 0 Anonymous, 1,398 Guests (See full list)
