Do i need to replace the rear suspension springs? Car too low in the rear?
This is my Project car! a 1972 240z! I have noticed that the car seems to low on the rear suspensión and always bangs on Street bumps! Do I need to replace the whole shock absorber? or just the springs. If it were the springs which Brand is recommended? Is there a set that comes with shock absorbers that come with springs?
1970 1978 Datsun 240Z 260z 280z Springs | eBay
I used Chevette springs cut to size and KYB struts all around. It firmed up the ride and got rid of the bang from the bumps. That's the budget build. Of course, I would only do this if you are mechanically inclined.
I still think the rear springs could be soft. The car does look low in the rear. What Brand of springs is recomendable? Eibachs? I want a smooth ride with the correct height of the car!
Edited by jalexquijano
KYB shocks and regular Tokico springs work well.
btw your car looks great! I love white Z's.
Datsun 510, 240Z, 260Z, 280Z, 280ZX, 300ZX and Roadster parts available from Upgrade Motoring!
What about Arizona Springs? Since i only need to two rear ones? http://www.arizonazcar.com/springs.html
Should i purchase this set?
Just called Dave! He ran out of stock! What other alternative do i have to achive stock height and ride?
If you're looking for stock ride, and height, you'll need to look for OEM stock springs.... I'm not positive, but I think pretty much anything out that is aftermarket lowers the car, and firms up the ride... Your best bet probably is either Ebay, or a salvage yard.
The springs from Arizona Z Car states that they are "Considerably stiffer than stock" not what you're looking for
Edited by peng155
Just scored a used stock set of 2 front and 2 rear springs from a 1974 260z with 32,000 miles on ebay. will i be able to replace the springs on my car with these ones? Even though they are from a 260z? Any difference in the height amongst both of these years?
  • Who's Online   2 Members, 0 Anonymous, 1,489 Guests (See full list)
