Wanted to get some input. Doing a total modified rebuild on a 1971 240Z. Engine is basically stock. I could clean, paint and reinstall the original radiator which is in good shape. Or should I replace it with a new aluminum radiator? Will it make a difference going with a 2 or 3 row radiator? There are many around $130-$150 on Ebay. Is there a difference in quality or are they all basically the same. I appreciate your thoughts and suggestions. Kevin
https://www.classiczcars.com/topic/50097-aluminum-radiator-swap-a-good-idea/
I have done this on other car with good results. Aluminum radiator dissipate heat faster, any extra row will help any radiator aslong cooling system is working correct, and also look nice. The down side heavy xx fluid, and mental is softer. It great for city driving/tracffic, stop and go. I would stay away for ebay stuff but that my idea opinion. If you do replace any radiator I would take the radiator out and turn the car on and flush the system with a hose (bottem). Fan is off/removed. I seen other friend replace a radiator in a 66 mustang when I open the radiator and see inside i could see metal debris on his new radiator.
Kevin, some of those aluminum rads will be well built and some will probably be crap.The original 2 row brass/copper rad was well built and you have it in your hands.
If you are not adding huge HP to the engine then the original should be fine.
I have done two 240z rads now and 4L of vinegar is what you want. Flush out as much crud as you can with a garden hose then lay the rad flat on the ground and fill it with the vinegar. After 24-48 hours empty and flush with lots of clean water.
Spray it black and install.
Chris
Edited by grannyknot
Original radiators are good, especially a 3 row. Find a local radiator shop to flush and pressure test it. For the most part the aluminum radiator is bling and saving some weight.
When i took my 3 row to a local shop that's been doing this stuff for decades said he was impressed how well that radiator flowed. You could spend the money else where.
I also believe the original radiator is fine. They don't make them like they used to. My only aluminum radiator experience is with more modern cars. Most notably, when the plastic tank on the side of my Miata radiator was showing that tell-tale mottled green/orange/brown camouflage coloration, I was advised to replace it before it blew up on me in the middle of nowhere. Not really trusting plastic components, I decided to buy a (yes, cheap ebay) all-aluminum radiator. It didn't fit right, and it leaked somewhere in the core. I had to file a dispute to return it. I then got an OEM-style aluminum/plastic radiator from AutoZone for about the same price. It came with a lifetime warranty. The first one I installed leaked, so I exchanged it for another, which has been working fine. I really wish I could have bought an old-school, brass/copper radiator instead. That would have saved me a lot of work. If you MUST go with an aluminum radiator, spend a few $$$ for a good one.
Although aluminum has better thermal conductivity then brass or steel, what makes one radiator more efficient than another, regardless of material used, is surface area exposed to air. More tubes, more fins means better heat transfer. Material choice is a lesser consideration unless weight is a concern.
  • Who's Online   1 Member, 0 Anonymous, 1,461 Guests (See full list)
