Running rich on idle and WOT
Drove around, got my engine hot and adjusted to specs.
Should've asked this earlier but how tight am I supposed to adjust?
For instance, on an intake clearance, should -
(1) .010 go in relatively easy and .011 can go in but with some force
OR
(2) .010 go in with some force and .011 not go in unless I really jam it in there?
Cause I adjusted with by (1) and maybe my valve "ticking" is due to loose adjustments?
Also I noticed the wear on my lash pad is uneven. On one side/half, the feeler won't have as much friction as on the other side. Is this normal wear and tear? And am I using the side of the lash with the stronger friction as the primary feeler contact for adjusting?
  • Who's Online   2 Members, 0 Anonymous, 1,160 Guests (See full list)
