Parking and Interior Light fuse melting
To pull the speedometer & tachometer
And the problem BETTER go away once the speedo is disconnected! The dimmer control gets it's wires from the speedo, right? If the speedo is disconnected, so is the entire illumination control circuit?
So what are you gonna do once everything (except the speedo) is disconnected and the problem still occurs? :ogre:
Speaking of interior lamps-
I've had my last two dome lamp bulbs fail because the filament de-soldered itself on one end. Is that normal? It's a new lamp, and when I replaced the bulb each time, all the metal parts still looked shiny-new! It must be creating a high resistance when the filament gets old and melts the end off.
  • Who's Online   2 Members, 0 Anonymous, 1,508 Guests (See full list)
