LED bulbs Don't work for turn signals
I got a pair of 1156 LED bulbs (they were on sale) to try in the back for the turn signals, and the only thing they do is turn on, with no flashing.
Does anyone sell some LED bulbs that will work properly? a set of 1157 LED bulbs would then be installed in the fronts.
thxZ
The design of the base and contact points isn't good either. I put in an 1157 for the brake lamp, and the light was on intermittently. I could jiggle the bulb to get it on, then after you lock it to the fixture, it goes out. the tiny little contacts just don't work right.
BTW- the first attempt with the rear turn signals used the SMD type bulbs, and the second with the front turn signals used the traditional LED bulbs. Also, when I tried the latter in the rear brake lamp, it created a 'hot spot' on the lens both with the brake off and even brighter with the brake on. Maybe the SMD-equipped lamps would be more like incandescent bulbs.
IMO, To use LEdDs in the tail lamps and any other lamp on the exterior body would involve re-engineering the lamp with an array of LEDs, like Dave (Zs-ondebrain) has done.
That is, until you can buy an LED panel that fills the lens with light.
Edited by TomoHawk
Thanks for the suggestion of the electronic flasher.
First of all, the AP websites all tell me that the (Tridon 35) flasher isn't compatible with my car. (just kidding ;) but after reading the last part of "Sold on LEDs" I think I will keep using the incandescent bulbs- no offense...
I just don't think I want to rewire the car just to try some different bulbs.
BTW- I was interested in usng the LEDs only on the turn signals because of the way the light "snaps" on&off, thinking it might add little safety when driving.
I will limit my use of LEDs in the car to the high-mount brake lamp, or the flashlight I keep in the tool bin.
Rewire the car? All you have to do is use a Tridon 34 and run a ground wire. *SMH*
Rewire the car? All you have to do is use a Tridon 34 and run a ground wire. If that's too difficult, consider selling your Z and buying a new Honda. *SMH*
I saw another discussion here that mentioned a Law Enforcement officer (LEO) might pull you over for having LED tail lamps. Why would they? Do some states have laws prohibiting the use of LEDs on older cars?
Lights can be a tricky thing, because the DOT is particular about the color, number and brightness of them. There are lots of mods out there, but their technical legality may be questionable. They may question your modified lights if the the lights and housings weren't designed together. Then again it may not matter on an old car.
IMO, the only reason I would think that Law Enforcement might not like your LED lamps is if they were done very badly.
New cars are "a dime a dozen," and usually adequately provisioned with bright lamps, so I would not even bother considering "upgrading" to LED lights. For the sake of an irreplaceable vintage vehicle, I thought of the LED lights because of the instantaneous illumination, and that they are usually brighter, for safety, especially for the brake lamps and rear turn signals.
I'm inclined to build the LED panel as Dave has done, but the bulb exchange seemed to be much simpler. The panels would be a long-term winter project.
Edited by TomoHawk
  • Who's Online   0 Members, 0 Anonymous, 1,385 Guests (See full list)
