280z engine in a 240zna lost the clutch yesterday so ...
I have a l24 flywheel in the garage can I have it surfaced and ready to go (in other words are the l24 and l28 flywheels the same )
Is it worth it to buy a lighten fly wheel on a NA car? I was think of saving $ and put it in my turbo car thought it would have a greater effect.
Thanks
DC
https://www.classiczcars.com/topic/50293-another-clutch/
You didn't give enough detail to give a good answer. Can't tell if the coupe is the L28, or the turbo, or if you have two cars, or just one car and two engines...etc.
The flywheels will all bolt up, but the pressure plate, clutch disc, and throwout bearing collar all need to match in order to work properly.
https://www.classiczcars.com/topic/50293-another-clutch/#findComment-457636
All L24/L26/L28 flywheels bolt to the crank, but not all clutches bolt to all flywheels. 225mm clutches use 6 mount bolts, 240mm use 9 bolts, in a different pattern. Sorry, the clutch pack has to match which ever flywheel you decide to use.
Only the Fidenza aluminum flywheel is drilled for both diameter clutches.
https://www.classiczcars.com/topic/50293-another-clutch/#findComment-457643
I have 280zx trans so I will use that collar with a clutch kit . I will get my spare flywheel surfaced . Thanks DC
The collar does not match the transmission. It must match the pressure plate (aka clutch cover). This stuff is all over the internet, numerous threads about major problems when parts get mismatched. You might browse around a little before you put things together.
https://www.classiczcars.com/topic/50293-another-clutch/#findComment-457645
