New member here, so I don't know if this has been covered before.
I've found a replacement for the original 280Z 280ZX AAR that works much better, is relatively cheap and best of all it's from Nissan. No more Toyota Cressida valves!!
Nissan part # 22660-45P00. These are off a Z32 300zx/early Infiniti J30 and will bolt right on to any 280Z or ZX. One slight modification is that the terminal locating tab on the electrical connection is slightly offset from the original. It's not needed. 5 minutes work with an X-Acto knife or file to remove it and you're done.
This is a new style " Rectangular " model that can be easily disassembled for cleaning and has a composite slide plate that resists sticking. A much better valve than the earlier " round " style. Bolt pattern and hose size is exactly the same as the original 280Z AAR.
I've found new OEM Nissan ones online from about $75 - $80. I lucked out and found a BNIB 22660-45P00 for $29.95 on E-Bay. Good used ones are plentiful as well as are aftermarket. Standard Motor Products carries them as Part number AC366. Rock Auto stocks them.
Measured resistance is 75 ohms.
Edited by Chickenman
https://www.classiczcars.com/topic/50310-a-better-auxilary-air-regulator/
Since my car is a 1976, I was going to update the PCV hose routing to the later 1978 style. This to reduce some of the oil contamination issues of the AAR. Then I decided to clean things up further and simply feed the AAR inlet through a small K&N breather vent. K&N Part # 62-1330 with a 1/2" id neck.
I'll take some pictures of the completed install a bit later.
That won't work right. The AFM won't know about the air being supplied by the AAR and you'll run lean until the AAR closes.
Just to clarify why it won't work, the AAR is an air bypass to the throttle blade, which affects (increases) idle speed when the engine is cold, but ALL air going to the engine must pass throught the AFM or it cannot set the fuel mix correctly. That little filter will pull air from atmosphere that cannot pass through the AFM.
That was my initial thought as well and you are probably correct... but I was thinking that as the AAR connects from the Valve cover and then connects ahead of the TB and after the AFM, that it would be OK. On second thought it may not be....
However, it may not affect the system all that much. Airflow values on the factory AAR valves are pretty low...around 5 cfm at 70 F. I'll test it out and let you know the results. It may help my particular car as it has a big cam and tends to idle rich with the TPS setup " properly "
My car has always idled too rich with the TPS adjusted properly, it actually idles better with the TPS adjusted so that the idle contacts are open at idle speed. This is true with either the stock cam or the 280 degree cam. ( and yes EVERYTHING has been checked, TPS operation, AFM mixture bypass on AFM has been adjusted to best vacuum reading " Lean Best Idle " , AFM calibration is spot on ..confirmed with DVM and 4 gas analyzer, brand new ECU CTS ) .
Even when fully warmed up my car idles better with TPS idle contacts setup " wrong " ( Contacts open at idle ).
According to the Nissan EFI Bible, when the TPS idle contacts are closed the ECU compensates by enrichening the mixture slightly. That makes sense as Idle mixtures are typically richer than Stoich. Combine that with low compression ratio's , retarded timing values ( relative to ideal non-emmission timing ) and sometimes EGR and it all adds up. However, my car now has 10-1 CR and lots of advance at idle. It doesn't seem to need the extra fuel at idle... on my particular car. Weird that the big cam doesn't like the extra fuel at idle though. I'm suspecting that ECU may be getting some " drift ".
That problem should be solved next year as engine will be getting a Mega Squirt 2 or 3.
The stock EFI system is a collection of parts that were all designed to work together. So, with the cam, you're out of spec. anyway.
I can't help but point out the contradiction in the above statements though. What you're really saying is that the gas analyzer specifications are too rich. For your nose, I assume.
Good luck with the tuning. Not sure why you want to remove the PCV anyway, since it actually cleans combustion byproducts from the crankcase, leading to a cleaner engine. Unless you're looking for that little bit extra of clean air and power that the PCV gases are taking up in the intake air supply at full throttle.
Not sure how it can work "better". I have an original style and it works correctly. Junk yard $2 find.
As Capt said, wont work right the way you want to install it.
Well that's all fine and good if you can find a Junkyard AAR. Then it's a crap shoot to see if the 35+ year old part still works. And you can't buy a new S30 AAR anywhere. They're just about extinct.
I've worked ( many hours ) on my 37 year old AAR valve trying to get it working properly and I'm just not satisfied. After much cleaning, adjusting and trying to get the heater coil " clocked " just right, the original valve still closes hit and miss. Not good enough for me. I have a new Cressida AAR valve and this new Nissan AAR valve. Both have composite slides..both are BRAND SPANKING new and both operate as smooth as a hot knife through butter. That to me is " Better "
As far as better? Yes they are better than the originals. Composite slider resists oil contamination better than stock, you can easily take them apart with 4 screws for cleaning or adjustment... and they aren't 35+ years old :beer:
You know what they say when you arse-U-me... LOL
Who said I was removing the PCV? Not me. I know the benefits of running a PCV and it is fully operational.
And yes the car was checked and setup confirmed with a Sun Allen 4 gas analyzer at Bills Datsun Shoppe in Claakamas Oregon ( One of the top Datsun specialists in the PNW. 37+ years in Business. The guys sharp ) ). And I'm no noobie to Datsuns or Race car/Street Car tuning. Have built and raced them since the mid 1970's. Not my first rodeo. I'm one of those old timers who can still setup a car with a timing light, vacuum gauge and my nose and ears. That's what we had to work with back then and these days there are few of us left. And my tunes all come out BANG on the money when the checked with WideBands, Emmissions Testing, Chassis Dynos etc. I'm no stranger to modern equipment either, but a good set of ears and nostrils can still give you an initial heads up to a problem.
You'll typically find me at the track tuning some one else's car. I actually do a nice little side business tuning Vintage cars and Hot Rods. I've got years of experience tuning Webers, Dellorto's, Mikuni's, SU's, Hitachi's, Holley's, Quadrajets, Rochesters and just about every carbed car under the sun. Mainly a Carb guy, but am gaining more and more EFI experience every day. Have been studying and Tuning Bosch Motec series for the past few years, both WB and NB.
I'm not bragging...just introducing myself as I'm new here...but not new to Datsuns :beer:
Edit: PS also have 17.5 years under my belt as a Certified Nissan Partsman.. just as an introduction. Did I mention I was an old Fart? ;)
I didn't say the gases weren't checked. I'm just wondering what you meant when you said that it's still too rich. It doesn't matter how many modifications you make if you keep tuning those modifications to the gas analyzer, and the gas analyzer specs. are too rich for your nose. You can tune to the analyzer, or tune to your nose.
And, no offense intended, but you should have seen the questions coming about the bypassing the AFM, with all of your experience. "All air must pass through the AFM" is one of the fundamentals of the EFI system.
Hmm....I never had to do anything to my AAR. It works perfect, period. Junk yard find was probably 15 years ago so it is original equipment. Besides the fact I have an extra original one in the garage. Thats the one I compared it to when I got it from the junk yard, salvage yard, what ever they are called these days.
Thats how I tune my Z...vacuum gauge, and timing light. And my dwell/tach for rpms.
Go ahead and brag man. We can use another well rounded mechanic here. Welcome to the club, BTW.
As you probably know already its tough to do tuning or performance engine upgrades due to CA emissions laws. Not sure what it is in Oregon, must be lenient there? I am curious on the results of the AAR you have so please post results.
To the basics of the original post - I like the find on the alternative AAR. I've seen the newer designs and pondered if they could be adapted. I'd probably get one from a wrecking yard if I went that way, but the one I have works fine, and I have two more that I've cleaned up and are ready for use if needed.
Nissan changed the PCV hose routing in 1977, because of AAR and throttle blade fouling. The newer AAR could have the same problem if the 76 hose configuration is still in place.
rcb, the OP is in Canada. In Oregon, I only have to pass idle emissions. All of my AAR's are stock 70's time-frame.
Edited by Zed Head
