I have no spark from coil. I have replaced the ign module in the distributor, new coil new cap and rotor. Set the points. If I scrape a ground wire to the ignition module in the distributor I can get it to spark.
You're either joking with the forum or you don't really have much idea what those parts are.  Post a picture of what you're working with if you can.  If you have an ignition module then you don't have points.  What year car is it?
