Posted November 19, 201410 yr comment_458890 I am having an issue with one of the direction arrows light on my speedometer as it remains lighted when i turn the light of the car on. I thought the problem was the turn signal switch, so i unplugged it. the left arrow still remain on. I started to jiggle the socket and now it does not turn on, so i believe the bulb must have burned. How can i fix this without pulling the complete dashboard apart? What kind of White led bulbs should i purchase to replace all these bulbs? Any supplier and part number? Anyone??? Link to comment https://www.classiczcars.com/forums/topic/50453-led-dashboard-bulb-type/ Share on other sites More sharing options...
November 21, 201410 yr comment_459018 buy a regular bulb replacement, the old one lasted 40 years. I pulled my dash and refurbished the entire thing so i cant comment on changing a specific bulb, there has to be a way though Link to comment https://www.classiczcars.com/forums/topic/50453-led-dashboard-bulb-type/#findComment-459018 Share on other sites More sharing options...
December 3, 201410 yr comment_459789 Replacing all the bulbs with LEDs is a nice idea (I did it, details here), but I also had the dash out of the car. The stock rheostat dimmer does not work with LEDs (it is either on or on)I also recall that some of the bulbs are not chassis-grounded, which means an LED bulb likely wouldn't work as I learned with my glovebox light experience.I agree 100% with Kurbycar32 - stick with the stock bulbs. If you can wedge your body upside down under the dash, you MIGHT be able to pull out the bulb (the bulb/socket combination is a press-fit).-----------WoodWorkerB Link to comment https://www.classiczcars.com/forums/topic/50453-led-dashboard-bulb-type/#findComment-459789 Share on other sites More sharing options...
December 12, 201410 yr Author comment_460265 Which model and Brand of leds will last longer and illuminate better on all the gauges of the instrument panel? Is the following Brand reliable or should i stick with superbright leds? http://www.amazon.com/Cutequeen-White-Lights-5-SMD-64111/dp/B00EZIQP6G/ref=sr_1_9?s=automotive&ie=UTF8&qid=1418421033&sr=1-9&keywords=leds+ba9s Link to comment https://www.classiczcars.com/forums/topic/50453-led-dashboard-bulb-type/#findComment-460265 Share on other sites More sharing options...
December 13, 201410 yr comment_460280 As far as brands go I have no idea but I just purchased these https://www.superbrightleds.com/moreinfo/bayonet-bulbs/ba9s-led-bulb-4-led/6/ and so far have only installed in the oil, fuel and clock gauges. They do dim with the rheostat dimmer on my 77'. I've noticed that with the less power drawn by the LED's my Speedo and Tach are brighter with their original bulbs. Haven't decided whether or not to change them also. The Difference in light color temp between white led's and the incandescent bulbs is equaled out if you leave the green tinted light filters in your gauges. Also got this for my map light https://www.superbrightleds.com/moreinfo/miniature-wedge-base/194-led-bulb-5-smd-led-wide-angle-wedge-base/206/919/ and it works great. You should be able to remove each gauge without removing the dash. That information is in the FSM. Also, check your exterior turn signal bulbs first. If a bulb is bad, that would cause your turn signal to not operate Link to comment https://www.classiczcars.com/forums/topic/50453-led-dashboard-bulb-type/#findComment-460280 Share on other sites More sharing options...
December 18, 201410 yr comment_460505 I have pulled my dash to do crack repairs, and have decided to replace the incandescent bulbs with LED. I've already bought the LEDs have replaced the old 194's with them. My Q is, which is the wire that feeds power to these bulbs? I want to test them before I put them back into the dash. Thanks all!Curtis Link to comment https://www.classiczcars.com/forums/topic/50453-led-dashboard-bulb-type/#findComment-460505 Share on other sites More sharing options...
February 4, 201510 yr Author comment_462931 Okay just logged in to superbrightleds website. Can someone point out which of the following models contained here shall i purchase for the gauges on the dashboard of a 1972 Datsun 240z? https://www.superbrightleds.com/cat/led-vehicle-replacement-bulbs/vehicle/1972-nissan-240z--instrument-general/43-40--6008/ I will be using them with the Green plastic in each gauge to mantain the stock look, so i will need them powerfull enough Link to comment https://www.classiczcars.com/forums/topic/50453-led-dashboard-bulb-type/#findComment-462931 Share on other sites More sharing options...
February 4, 201510 yr comment_462948 I bought some inexpensive LEDs off ebay and installed them in my 620. They're so white and bright that the green lens has almost no effect. The LEDs are too long to install in the tach because they hit the green lens. I have one LED partially resting in the socket and nothing in the other socket and it's still much brighter than when I had two bulbs in there. The LEDs are amazing. I can read everything on the tach and speedometer. I can even read the odometer at night. If you want the green light then I suggest getting green LEDs. The green lens does nothing. Chuck Link to comment https://www.classiczcars.com/forums/topic/50453-led-dashboard-bulb-type/#findComment-462948 Share on other sites More sharing options...
March 29, 201510 yr comment_466715 On 2/4/2015 at 2:03 PM, cbuczesk said: If you want the green light then I suggest getting green LEDs. The green lens does nothing.You should always get an LED the same color as the filter. E.g. Amber LED for front blinkers, red LEDs for brake lights. Link to comment https://www.classiczcars.com/forums/topic/50453-led-dashboard-bulb-type/#findComment-466715 Share on other sites More sharing options...
March 30, 201510 yr Author comment_466798 On 3/29/2015 at 6:20 PM, bvolken said: You should always get an LED the same color as the filter. E.g. Amber LED for front blinkers, red LEDs for brake lights.What size of leds? we know its BA9s, but what size? Link to comment https://www.classiczcars.com/forums/topic/50453-led-dashboard-bulb-type/#findComment-466798 Share on other sites More sharing options...
March 30, 201510 yr comment_466800 The 7 led BA9's I purchased from Amazon are 20mm x 12mm. They fit perfect. http://www.amazon.com/dp/B00BY0ESVC/ref=wl_it_dp_o_pd_S_ttl?_encoding=UTF8&colid=2NDSEKXCIOHGL&coliid=IKRCLTS7706ND Link to comment https://www.classiczcars.com/forums/topic/50453-led-dashboard-bulb-type/#findComment-466800 Share on other sites More sharing options...
April 1, 201510 yr comment_466899 On 3/30/2015 at 9:03 PM, jalexquijano said: What size of leds? we know its BA9s, but what size? I have part numbers and photos on my web page woodworkerb.com changing instrument lighting. One type for general illumination (e.g. under the green bubbles) and one type for focused illumination (e.g. blinkers, high beam) Edited April 1, 201510 yr by bvolken Link to comment https://www.classiczcars.com/forums/topic/50453-led-dashboard-bulb-type/#findComment-466899 Share on other sites More sharing options...
