I've been doing research for a few weeks now and asking around and trying to gauge what will fit and not rub. I have an 11/70 240z with the stock rotors, hub and suspension and want to put an 8 spoke wheel such as the Watanabe's, Panasports or Rota RB's on my Z. I have narrowed it down to 15x7 wheels with a 205 size tire (heard that this is what to use for the setup I have. I was hoping for some input on the offset though. Any and all help would be appreciated and if I have my facts wrong at any point, please let me know!
Chris
https://www.classiczcars.com/topic/50460-wheels-beating-a-dead-horse/
This may not help much but I have 15" panasports on mine, but not sure of the width or aspect ratio. I like the look, it doesn't fill up the wheel well as much as some of the 16" setups I've seen. With low aspect performance tires my total wheel/tire combo has a smaller diameter that stock which impacts my speedo.
Love the look though
The wheels that came with my car rubbed, and I skinnied down a bit.  Here is the relevant thread:
http://www.classiczcars.com/topic/33495-wheel-rubbing/
I'm still happy with my tires.  I haven't had any rubbing problems, and the steering is much easier with a slightly narrower tire (closer to stock dia and width, but on a 15x7 wheel).
It is the front lower valance on a stock Z that you have to worry about IF the car is lowered.  ON stock springs you would probably be okay.
I had to run 205/55/15's.  OR 195/60/15's.  205/60/15s rubbed when I turned and backed out.
Just keep it a bit conservative and you will be fine.
Here's what I'm waiting for, http://www.discounttiredirect.com/direct/findWheelDetail.do?bp=4-114.30&fl=&pc=45470&counter=1&wd=15&rw=7
They've been out of stock for a month at least but promised me they will have them before Christmas.
I'm sure MSA would have 0 offset too.  Call them, ask about their holiday sales.  They're doing a 3 part sale.
