My 240z presents some window rattling on the driver´s door when i drive. If you close the door with the window fully down it sounds as if the window will fall. What could be missing? Any kit that sells all the inner seals, Windows felt, etc?
The window rollers are notorious for breaking off. If you can't see it when you look down into the window door opening, it's probably in the bottom of your door. MSA has the window roller and the door window channel seals.
http://www.thezstore.com/page/TZS/PROD/30-2151
http://www.thezstore.com/page/TZS/PROD/classic03a05/34-1052A
Thanks Sean,
What else would you recommend replacing besides the window rollers and door window cannel seals on both doors? I just want to make one sole order.
  • Who's Online   1 Member, 0 Anonymous, 1,300 Guests (See full list)
