Master & Wheel Cylinder Rebuild Kits?
I switched the short hardline from one side to the other and had less bending to do to make them work.  http://www.classiczcars.com/topic/50122-early-72-wheel-cylinder-problem/
If you do get the cheaper Centrics you may have to bend the the flat steel arm that catches the adjusting wheel.  Your e-brake is supposed to adjust after a few pulls but mine didn't.  So I took the tire back off and saw that arm wasn't making contact with the teeth on that adjusting wheel.
  • Who's Online   0 Members, 1 Anonymous, 1,470 Guests (See full list)
