Converting From Efi To Carbs, What Can I Get Rid Of?
These may help:
You may wish to buy a later 280z oil pressure sensor and connect a normally open switch.  The switch would wire to 36 and 39 and close when the engine was running (usually not in a crash).  You would have to keep the EFI relay to keep the functionality.
Haz, I said I removed all relays but now remember I did not remove the EFI relay. I did leave it installed. Removed everything else.
Blue's right, that's why I said check your fuel pump circuit. Not sure if its the same as the 77.
It looks like the 75 use's a different EFI relay than the 77. At least it seems that way, there are two different part numbers. So my way of wiring probably wouldn't work for you anyway. Besides I still can't completely remember what I did. It was 1994, 21 years ago.
Sorry I couldn't be of much help.
  • Who's Online   1 Member, 0 Anonymous, 1,459 Guests (See full list)
