I have dual Spal fans and a 3 core aluminum radiator for my car. The fans are a little over 4 inches. It doesn't seem like the fans will fit. I've seen pictures where there are fans and an aluminum radiator. Does anybody have this setup or have any info? Thank you very much.
I have the 3 core radiator, and had to go low profile fans. I am down to about 2.75 inches, which gives me about .75 of an inch to the front of the motor. I've seen some setups that run push fans at the front. Don't know if you want to try that.
I purchased these recently to go along with my Champion 3 core aluminum rad. Seem to fit fine, although I'm not too impressed with the amount of air they pull.  They keep it cool now, but I'm curious about the summer.  Curious about how long they will last too!
http://www.amazon.com/Performance-Electric-Radiator-Cooling-Assembly/dp/B00H29LGI2/ref=sr_1_1?ie=UTF8&qid=1418247866&sr=8-1&keywords=10%22+cooling+fans
