I was hoping you guys might be able to clear something up for me. I read that by putting the carb intake manifold on your 240 it may increase the hp by a tad. Has anyone done this and does it make a difference? If not a HP gain is there a benifit to swapping out the stock 240z's for the 74 260's? Also is there any place that lists the carb intake manifolds model number that was on the different years of z's. I wondering about this so I would be able to tell if I was buying the right one. Thanx in advanced,
Bart
1971 240Z
https://www.classiczcars.com/topic/5064-carb-intake-manifold/
I searched and found a ton of valuable info, I will be sure to do a complete search before asking questions in the future. Though I still have a question after doing my searching and was wondering if anyone could help.
I read about the N33 manifold which from my reading appears to be found stock on 1973 240Z's. Then the N36 was found on all 260's. Someone mentioned in one post that I found that the N33 and the N36 were essentially the same thing. How true is this. I am assuming that sticking an N33 on there would bring me the same benifits as sticking an N36 on my 240z. Is the assumption correct or would there still be another benifit to having a N36 or a N33?
Also it seemed that the majority opinion on the N36 regarding HP was that only a highly modified engine would benifit a HP increase. If this is true would the same car experience the same thing from an N33 and if so how close would the benifits be compared to the N36.
Thank You all,
Bart
1971 204Z
  • 4 weeks later...
you ansered your own question the 33 and 36 are the same. here is a vary good web site for this kind of info. geocities.com/zgarage2001/engine.htm I doubt that you would be able to feel the difference between the manifold that you are useing now and either the 33 or 36 . On a dino maybe. try the web site there is a ton of information there . Gary:classic:
  • 3 months later...
I have a N36 Intake manifold that I'd be willing to trade to someone for an E88 Intake manifold that is in similar good condition. I don't really need it and I'd be just as happy with an E88 for my car.
If anyone is interested, send me a PM.
********EDIT********* The offered N36 Intake is no longer available. Traded it for a E88 today 7-13-2003
  • Who's Online   0 Members, 0 Anonymous, 1,413 Guests (See full list)
