Johnny wick Posted December 22, 2014 Share #1 Posted December 22, 2014 MY RH fender dettached from the car on its bottom left corner: http://www.showcars-bodyparts.com/240z-p-fender-rh-newsteel.JPG Should i hire someone to solder it back? I can see some rust underneath. It will be temporary until i finish replacing the cam and installing the ac system. Link to comment https://www.classiczcars.com/topic/50642-rh-fender-came-loose-on-bottom-left-corner/ Share on other sites More sharing options...
gnosez Posted December 22, 2014 Share #2 Posted December 22, 2014 self tapping screw. They were held on with bolts so don't solder it. Link to comment https://www.classiczcars.com/topic/50642-rh-fender-came-loose-on-bottom-left-corner/#findComment-460701 Share on other sites More sharing options...
TomoHawk Posted December 29, 2014 Share #3 Posted December 29, 2014 If you can, weld on a heavy plate with the correct threaded hole in the same place as the original one. That way you can protect it with rustoleum and copper antisieze, in case you need to remove the fender some time in the future. You may also consider the cowl drain upgrade, so there is less stagnant water on that area of potential rust. Link to comment https://www.classiczcars.com/topic/50642-rh-fender-came-loose-on-bottom-left-corner/#findComment-460920 Share on other sites More sharing options...
