oranngetang Posted June 3, 2015 Share #205 Posted June 3, 2015 Link to comment https://www.classiczcars.com/topic/50701-2015-what-did-you-do-towith-your-z-today/?page=18#findComment-471159 Share on other sites More sharing options...
Red7 Posted June 3, 2015 Share #206 Posted June 3, 2015 (edited) Got the auto electrician around today to fit the JDM Euro Spec tail lights we need over here, change the front running lights to indicators and the headlights to include side lights we also need, and fit relays and resisters where necessary, on Friday it's going for its MOT, Ministry Of Transport Test, every vehicle here must have an annual test if older than 3yrs old, also I received from our friends from Z car Depot, new front and rear bumper rubbers, an OEM passenger door mirror, door gromits, cone shaped rubber that fit in the B post, courtesy light switches ( the push switches in the doors that make the interior lights come on when you open the doors, sorry for the explanation you may call them the same thing ;-) ) Happy Days Edited June 3, 2015 by Red7 3 Link to comment https://www.classiczcars.com/topic/50701-2015-what-did-you-do-towith-your-z-today/?page=18#findComment-471190 Share on other sites More sharing options...
psdenno Posted June 3, 2015 Share #207 Posted June 3, 2015 My rebuilt carbs from ZTherapy were delivered by UPS at about 7:00 last night. This morning I took a couple pictures (because they will never look this shiny again) and then took them to my mechanic for installation and tuning. I've posted the pictures for those who haven't seen what one gets in the box from ZTherapy. http://tinyurl.com/pgajmmcDennis 2 Link to comment https://www.classiczcars.com/topic/50701-2015-what-did-you-do-towith-your-z-today/?page=18#findComment-471219 Share on other sites More sharing options...
oranngetang Posted June 4, 2015 Share #208 Posted June 4, 2015 After a late night putting the 5 speed in, took a 800 km cruise to Kamloops for the week. Averaging 23 US MPG so far on SM needles. Diff clunk 100% gone. 3 Link to comment https://www.classiczcars.com/topic/50701-2015-what-did-you-do-towith-your-z-today/?page=18#findComment-471231 Share on other sites More sharing options...
Patcon Posted June 4, 2015 Share #209 Posted June 4, 2015 Was the diff clunk the worn u joint? Link to comment https://www.classiczcars.com/topic/50701-2015-what-did-you-do-towith-your-z-today/?page=18#findComment-471245 Share on other sites More sharing options...
Diseazd Posted June 4, 2015 Share #210 Posted June 4, 2015 My rebuilt carbs from ZTherapy were delivered by UPS at about 7:00 last night. This morning I took a couple pictures (because they will never look this shiny again) and then took them to my mechanic for installation and tuning. I've posted the pictures for those who haven't seen what one gets in the box from ZTherapy. http://tinyurl.com/pgajmmcDennisPure art! Link to comment https://www.classiczcars.com/topic/50701-2015-what-did-you-do-towith-your-z-today/?page=18#findComment-471283 Share on other sites More sharing options...
oranngetang Posted June 4, 2015 Share #211 Posted June 4, 2015 Was the diff clunk the worn u joint?Partially. I've had the car up on jack stands idling in 1st gear and it would visibly rock inside of the mustache bar. I've since welded a 3/8" plate to the mustache bar and run in bolts, rather than studs which completely eliminated the rocking, but there was still a small amount of play and some binding happening. I assumed it was the differential since I welded the spider gears in it.The driveshaft '70 non servicable driveshaft I removed had a blown u joint on the differential side and replacing it with with 280zx shaft that I shortened completely removed ALL play in the driveline. There is still vibration that begins at 58 mph, and exponentially increases with speed, but will vary with appied torque if that makes any sense. I feel again that this is the differential, possibly from the significant amount of wire welding I've significant doesn't to the carrier, with worn bearings, but possibly it's just the u joint half shafts. If the trouble exists after a cv swap and sti last swap... I'll be upset. Link to comment https://www.classiczcars.com/topic/50701-2015-what-did-you-do-towith-your-z-today/?page=18#findComment-471284 Share on other sites More sharing options...
oranngetang Posted June 4, 2015 Share #212 Posted June 4, 2015 ... and not to leave out the very unbalanced home cut driveshaft Link to comment https://www.classiczcars.com/topic/50701-2015-what-did-you-do-towith-your-z-today/?page=18#findComment-471285 Share on other sites More sharing options...
racer47201 Posted June 4, 2015 Share #213 Posted June 4, 2015 Yesterday I purchased a !982 280ZX NA 5 speed for a parts car. Going to pull the engine/transmission and r200 to augment my 77 280Z 2+2 auto. Are there any other parts that I might use for my 280Z? Will the pedals transfer to the 280Z? Link to comment https://www.classiczcars.com/topic/50701-2015-what-did-you-do-towith-your-z-today/?page=18#findComment-471286 Share on other sites More sharing options...
oranngetang Posted June 4, 2015 Share #214 Posted June 4, 2015 (edited) Pardon my grammars.... Samsung issue. Mount Robson Just finished a road trip to the Kamloops area, roughly 2,000 km round trip with the new transmission. Epic! Lots of scenery along the way and thumbs up from passers by and round crews. 3rd gear has some enormous pull. Shifting from 2nd at 7000 rpm to 3rd is like turning on nitrous. Edited June 10, 2015 by oranngetang Link to comment https://www.classiczcars.com/topic/50701-2015-what-did-you-do-towith-your-z-today/?page=18#findComment-471287 Share on other sites More sharing options...
anthony_c Posted June 13, 2015 Share #215 Posted June 13, 2015 spent the annual datsun allowance installing new kyb strut cartidges, mounts, bearings, and ball joints.not an inexpensive job, but it made a huge difference. the ride went from being quite unpleasant to downright soft. Link to comment https://www.classiczcars.com/topic/50701-2015-what-did-you-do-towith-your-z-today/?page=18#findComment-471880 Share on other sites More sharing options...
moelk Posted June 13, 2015 Share #216 Posted June 13, 2015 Went to a car meet and track/drift day. And there was a Z on the track and some realy nice rides to look at. Link to comment https://www.classiczcars.com/topic/50701-2015-what-did-you-do-towith-your-z-today/?page=18#findComment-471881 Share on other sites More sharing options...
