The welds are supposed to be seam welds but are the closest I could get inside the piece with my mig gun. They are there to "gusset" the corners or "folds" to reinforce them. Remember, I had to score the folds with a cutoff disc in order to bend them first. This way, they will be stronger and will withstand more pressure or small impacts and hold their shapes better and longer.
So I have left this opening between the rails to hopefully drain any moisture that gets into the frame rails. This will be the lowest point on the frame and the connecting panel has 1/16" of space facing the rear of the vehicle between the floor rail and connecting rail. This should allow an egress point without giving it an ingress point...
IMG_4137.thumb.JPG.885a6282fb1e89f0865f1
you are doing a great job there [emoji6]
well done!!!
Thank you! I am really enjoying this part, which surprises me. Learning a lot and feeling more confident as I go.
Yesterday I was reminiscing about when I first found the car and thought to myself, "I can probably get this car fixed up nice for about 10 grand....!" thinking it only needed some minor work and cleanup. Boy was I mistaken... In the end, deciding to rotisserie the whole car was the best decision. I don't flip cars (pun intended), so I will be keeping this vehicle in my collection. No point in not doing it right.
Also repaired the lower rad support. Decided to cut the bottom open, bash the metal flat again, frame coat it, and re-weld it together again.
IMG_4143.thumb.JPG.592586f1121b3e8b05f5c
IMG_4150.thumb.JPG.ea4ea33091bdd8f1f4e73
Mostly straight again and now it will hold the original nacelle pieces properly.
  • Who's Online   1 Member, 0 Anonymous, 767 Guests (See full list)
