Awesome!  I need to get that stuff for my wife's FJ Cruiser.  I coated the whole frame with POR-15, but I haven't done the inside of the rails yet.  Toyota frames are horrible for rusting out.  I had a scrap her old 4Runner due to frame rot.
Thanks! If you look carefully, you can see the ceiling fan in a couple pictures that pumps low volume flow through a filter from the roof. It gets fresh air from the side soffit. The large pan on floor creates a draw down area under the chassis and vents through a filter out the back of the garage.
Durablock hook and loop. 320 and 400. I also have an random orbital air sander with a 120 grit for cutting the fibreglas down. Expense is relative. If you buy three times as much to do the same thing, are you saving any money? The fibreglas is working well. I have sanded and refilled for the last three hours and I am liking the results. I will clean it up further with glazing putty after I respray the primer.
I agree, I tend to splurge on good materials because the labor is free and I don't have a lot of spare time. I am glad the fiberglass is working out...
  • Who's Online   0 Members, 0 Anonymous, 1,611 Guests (See full list)
