The reason for the fibreglas filler is that I wanted to ensure all weld points were sealed and waterproofed. After that, some welds were brutally done along with shoddy repairs to the quarter panel. I did not want to cut a new panel in so I am patching with fibreglas. The new products may be better than I remember, but I will do all the finish work with either a hi build spray filler or professional bondo.
Sample PO repairs:
That looks really good.  I'm assuming you have some good long blocks for that line.  At this point you should put on a guide coat and see how things are coming.  It's hard to pick up detail with all the fill lines and general blotchiness.
Let me clarify.... about $10,000 in parts and another $10,000 in exchange and shipping. By the time I ship everything I need from the states it will be almost double! And the motor will only be refreshed, not built as I am sticking to stock power for now. Waiting for a better ecu solution before I ramp up the power.
  • Who's Online   1 Member, 0 Anonymous, 1,274 Guests (See full list)
