Bolted the Wilwood prop valve to the Nabco warning light distribution block.
Routed the rear brake lines back to the stock prop valve.
And yes, that is a bit of paint that peeled where a residual drop of brake fluid from the master cylinder fell onto the front rail. I will have to touch that up later... [emoji35]
Mark, you installed the brake lines while the car was still on the rotisserie? That is completely cheating! Wish I had thought of that.
Hey take lots of pics when you do the coil over cutting, I think I have that job coming up and would appreciate any tips. Looking very good.
Will do Chris. I finished my last two brake flares (hopefully) today too. Had to use imperial fittings to the prop valve.
My son in law is looking forward to the coilover work too. He will do the stick welding...
  • Who's Online   2 Members, 0 Anonymous, 1,565 Guests (See full list)
