Won't the welding burn the plastic of the coating?
The powder coat is cured at 450 degrees. The welding will be done with wet rags around the spindles and anti splatter spray on the exposed parts. Shouldn't be an issue.
Welding day yesterday...
First we MIG'd the struts with a tack to get the right offset from the collars. I wanted a good clean bite for the stick welds.
Then a solid bead around the collars.
Next step, clean up the welds and paint the exposed metal.
