@wheee! great work! Will you use closed cell foam in certain areas or leave it like it is? The only thing I don't like is that these tar mats are that heavy.. should be 10-15Kg (20-30lbs) if you cover all of the interior?
Edited by german240
I removed 80lbs of undercoat at least so I am not concerned with the soundmat. Plus it’s butyl, not asphalt so it’s a bit lighter. I do have the closed cell foam floor mat to go on top of the floor pans too.
The rest will get carpet backing and carpet to cover it. I also have the Techno Toy Tuning spare tire cover in powder coat for the rear!
So after three attempts to deliver the correct gas tank straps, I have received the correct set as of today! Skillard makes a great products and the quality is awesome. At least now I have the correct lengths for my 76!
The previous 77-78 version was an inch or so short each side. The 70-74 set were wildly different.
77-78’s here next to the originals.
Good eye. The pitting was on the original metal. I wasn’t too worried as this was a test. I have another one in better shape.
I used the gloss coat on top too. Big mistake. Looks like crap.
Started fresh... no gloss on this one.
  • Who's Online   2 Members, 0 Anonymous, 1,460 Guests (See full list)
